- Aug 7, 2007
- Costa Mesa, CA
- State - Country
- CA - USA
- Other
- 2004 Bronco Badlands
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 1.5"
- Tire Size
- 33"
For several weeks I have been having idle issues. Sometimes it would be normal and other times it would be high ranging from around 1600 to 1000 rpm. The high ide got more frequent as time went on. Sometimes when after decelerating it would kind of hesitate when I stepped on the accelerator pedal and then it would jump forward quickly. This did not happen often and only after driving it long time.
I kept thinking it seemed related to a vacuum leak but could not figure out why it was so inconsistent. Then I realized the PCV valve was a controlled vacuum leak and if it was not working properly could possibly give me these symptoms. I felt that it may be the only thing that could do this and be inconsistent.
I had not changed the PCV valve in a while and they are not too expensive, so I decided to change it. The 4.0 SOHC engine has it in a kind of difficult place for accessibility but certainly doable. I have been driving it for 2 days now and idle is back to normal. I have not driven it long enough to experience the hesitation part, but I suspect that is gone too.
I hope this helps anyone else that may be having a similar issue.
