truckman
Little history on the motor its a remain w/ 27,000ish on it has a comp cams stage 2 cam, shorty headers, offy intake and holley 390cfm, dura sparked w/ the GM 4 pin unit.
Now for the problem i put a new dist. from napa in after i trans plated the motor in to my new truck. got a new modual, new cap rotor and plugs and wires.
Go to fire it up runs ok at idel set base timming at 10deg. go to take it for a drive it runs ok at low rpm like just a little throttle. Put it under any hard load it will kick and buck take off and sounds like its missing on 1 maybe 2 cylinders let it go back to idel it runs fine and free revs fine a lil pop out the carb every now and again.
I've played with the timming for 2 days and had now luck i've never had this problem before with this.
I'm looking for suggestions to fix the miss fire.
Thanks,
Zack
Thanks,
Zack
