bad lock cyl. - NEED HELP!
tomahawk350
Solid Axle Swap
Johnstown, PA
2.9 V6
Last nite my keyswitch went bad at a gas station, the truck is still there. I can't insert the key. How do I go about removing/replacing the lock cylinder? I already removed the steering column plastic.
BTW its a '92 ranger ext cab....
thanks!
If you can't turn it to the run position I believe your only option is to drill it out.
thanks, luckily for me my dad knew a locksmith that came and picked out a pieice of brass that broke off inside the lock cylinder. $25 and no aggrivation of messing around trying to change the lock cylinder, thats worth it i think...
glad to hear you got it sorted out especially for that price. drilling them out is a royal pain in the neck.
