marc11
- Sep 8, 2008
I noticed an odd vibration/rubbing type noise at certain speeds recently, I jacked up the front end on the drives side front wheel will move about an 1/8 of an inch or so if I pull on it. It isn't a bad ball joint, they aren't moving. I took the wheel off and can move the rotor back and forth as well.
Bad bearing of something else? If it is a bearing, what sort of job am I looking at to replace it?
