Bad Fan Clutch
dper299
New Jersey
2.9 V6
I have a 99 ranger with the 3.0 Flex motor. With the engine off the fan turns with same amount of movement/ resistance at operating temp as it does when it's cold . Should I not be able to move it at all once the the engine has become hot ? I am guessing the clutch is bad ? Any help is appreciated..thanks in advance:icon_confused:
A thunderbird electric fan is a quick easy cheap fix for this.I cost me much less than a new clutch.see if it wiggles on the shaft or has oil residue around it.
Tim, can you post the year and size (and part # if you have it) of the Thunderbird electric fan you used? My fan clutch is starting to go bad and I may do the electric fan replacement.
Thanks
Mine came out of a 1996 4.6 thunderbird i belive. I got it for like $25 at the local pullapart.
