- Jul 23, 2009
- ON Canada
- 4.0 V6
- Automatic
04 B4000 2wd auto 378k kms.
Truck lost ac some time over the winter,
Last spring I installed a new clutch and coil,
Coil has the correct resistance.
Approximately 110 psi on both sides.
High and low switches have continuity.
Relay and fuse tested good.
I'm not seeing 12v on the coil connector when ac or max ac is selected.
Most likely a bad control panel at this point?
Thank you
Thank you
