yellowoctupus
Unfortunately my intermittent running issues have not gone away yet. They don't seem to be related to any type of driving (smooth roads, bumpy driving, cold/hot engine, run yesterday, run a week ago...running, then dying, not running then running......) Sometimes I'll go out to it after sitting, it will fire right up, then die like 200ft later.
Replaced normal stuff so far (to find the bad map sensor, and this contproblem)
Battery
TFI
Cap, rotor
Wires
Plugs
MAP sensor
Fuel Pump relay, ECM relay and associated connectors
All engine wires look good, I pulled them all down (elec. tape etc, coverings etc) today when I was stuck (not in mud, just not running) back in the woods. No spout wire grounding out from the tfi (at least as far back as the heater, I didn't unravel the wires down there yet. It will run GREAT! fire right up etc etc. then just DIE-no sputtering, nothing, sometimes when I'm accelerating, sometimes when I'm just on the gas a little or something, doesn't seem to matter.
Now, after the lengthy intro, do computers or ignitions (like at the key) ever go bad intermittenly? I also tried jumping the ecm relay manually to try getting around the key ignition, is that all you need to run (hotwired) these things? If anyone knows how to check the key ignition, that'd be great too.
Battery
TFI
Cap, rotor
Wires
Plugs
MAP sensor
