bad clutch master cylinder?
swynx
lewiston idaho
so i was bleeding the clutch on the pickup a different way...
i bought a 60ml syringe filled it with brake fluid, hooked it up to the bleeder and opened it up, i pushed fluid thru untill i couldnt any more, then i hooked up my bleeder gun to the master cylinder hose, and pulled the clutch master cylinder from the firewall and applied pressure, i got a ton more bubbles out.
installed it back into the pickup, and had the firmest clutch peddle i have felt since i have owned the pickup. started it up but still couldnt shift into any gear.
so i pulled it back out of the firewall and proceeded to bleed more air, i accidentally pumped the gun up to 25 psi and then i started getting a crap ton more air, i dropped it to 15 and closed off the bleeder valve, and it still keeps leaking like theres a leak some where. after messing with it for another hour i left it like this for about 2 hours peridocially checking on it, and its just bubble after bubble.
i now have no peddle at all ( it does come off the floor) but i have no pressure again.
the clutch master is the original as far as i know. so i suspect that to be the bad part.
The way I've been bleeding these things is to just barely crack open the bleeder, then very rapidly start stomping hard on the pedal about 6-8 times, checking the fluid level after every 6-8 times. So far this has worked for me each time I've done it (3-4 times now).
If you cannot get a useable pedal no matter what, then it's quite possible your MC is bad (if the pedal has some resistance but then sinks down like there's a leak, but no fluid is actually leaking from underneath, then this points to a likely bad internal seal within the MC).
Once you get it bled again make sure you have the clutch rod seated correctly over the pin on the clutch pedal. When I replaced mine recently the clutch was the hardest that it had ever been. I was going about 70 down the interstate when the toe of my boot just knocked the pedal and it slipped to the floor. After I stopped, I pushed the rod all the way down and now my pedal is back to normal. The only thing that I can think of is, I never had it seated all the way. And it was causing the bind in the pedal. It is a night and day difference. I had drove it with the stiff pedal for over a month. I'm on my 3rd clutch in 25 years on this truck but this is the first time I changed the master cylinder. It had developed a leak at the top where the rod seats. I bench bled the cylinder first and the got my stepson to pour in fluid while I cracked the bleeder though a tube from the slave cylinder. So I knew it was bled correctly. I just couldn't figure out why it was so stiff. Good luck. It always seems it is the smallest things that drive you nuts.
Sent from my RCT6773W22B using Tapatalk
