- Aug 9, 2007
- Age
- 41
- auburn/minot maine
i just changed the upper and lower ball joint on a dana 35. now with the camber bushing in and the bolt tight. i still get some slight play. but i am moving the steering knuckle with out a tire on it. also i do have grease between the bushing and the ball joint shaft. and the bushing and the i beam. with the upper ball joint stud all nice and tight. the upper ball joint shaft moves in the camber bushing. is that ok?
