back glass help
tylork92
Wanting to change out my sliding back glass for solid one in my 93 extended cab and am wondering which gens will fit.....or are they all interchangeable. please give me years of gens as i dont kno which years was what
Is your truck an extended cab also? If so the windows should work. If it is a regular car and you are wanting to install a extended cab rear window then no. The Extended cab rear windows are taller.
where are you located? i have a solid and would love to swap for a sliding
I believe 93+ extended cab only. i have one laying around here too, if youre anywhere near binghamton, ny. some bolt in, some use a rubber seal.... but they will both work because the ranger has tabs for both.
I'm in NC. Some people on another ranger forum said all extended cabs were interchangeable.
From what I found 86-08 rears glass is the same... I personally first hand don't know.
well went and got the window this morning. from what ive read on other forums multiranger is right. So for $30 i think its a good deal
yea i ment the extended cabs from those years are the same.
