B400 Eletrcial issues
cougar9150
B4000 Electrical issues
I don't post here often but have run into some issues with my 98 B4000 Auto that I need help with. I recently had some charging issue and had to replace both the Alt and battery. I also crimped and soldered new ends onto all the cables also as they ends were previously pretty corroded.
The day I replaced the alt but before I replaced the battery I drove the truck home after installing a new alt from Adv Auto. I get home and the lights are flickering and my battery gauge is reading really low. I whip out the multimeter and check the voltage and I'm watching as it slowly drops.
I go to jump the truck from my Marauder w/a 250A alt and see a big spark when I hook up the cable to the Marauder battery so I look back at the truck side and it is hooked up backwards on the truck side. I yank the cables off, connect them correctly and jump start my truck. Took it to the store and had the battery tested and it was bad and wouldn't hold a charge.
Now I have a new alternator and a new battery but I'm only getting 12V out from the Alt (Alt tests good, took it to a store other than where I bought it from). I pull off the negative terminal and hook up a test light and i lights up when I hook the probe up between the negative terminals and negative cable. I start pulling fuses and first one that affects it is the IP fuse (50a) but I still have a bright light on the test lamp. I disconnect the PCM and the light shuts off completely.
I measured current with the PCM connected and I'm getting nearly 2.5 amps draw so I know it's toasted. I move to the interior to find the other shorts in the IP fuse panel. The 3 Fuses I found shorts on are Fuse 25 (generic electronic module(GEM), instrument cluster), Fuse 29 (radio), and fuse 35 (RABS test connector). With the test light connected all 3 off these circuits will show a short but I haven't measured current yet but my test light is very bright. I plan on swapping the radio out with an aftermarket unit I have to fix that issue, but I have questions in regards to the GEM unit and the RABs test connector.
I know the GEM is bad because C7 on the board is fried and this is the circuit that connects to Fuse 25 and splits off to pin 7 on connection C3 of the gauge cluster and Pin 11 of the T-224 connector. With just the gauge cluster connected there is no short but with just the T-224 connector plugged into the GEM it shows a short again.
For the GEM unit I'm wondering what years would be interchangeable as I have found several different part numbers but I'm not sure which ones if any would be interchangeable for different model years so I can hit the junk yard. Or if anyone could tell me the size of the capacitor on C7 I could just replace the faulty component. There's no way I can measure it or identify a part number as it is completely blackened and unfortunately I can't find a schematic of the module itself. The P/N on the module is F87B-14B205-DD.
For the RABs test port I haven't dug into much or even looked at the section of the schematic. I'm half hoping I could just disconnect it for now and hopefully didn't fry the unit or if anyone could give me a heads up on any issues they have had with the RABs unit.
Thanks for any help,
Phil
No help on the multifunction (GEM as the manual says) module anyone. Just would like to know if I could swap out the part number in my first post with any other numbers. Like the unit I have says it's for the 2wd, 2 wheel abs, keyless entry. The truck didn't come with a key fob when I bought so could I use the unit from one without keyless entry?
Sent from my SPH-D710 using Tapatalk 2
