b2300 1997 rough idle and stops
ktm-boutin
Hi I just changed the engine of my b2300 1997 and since that, the engine idles rough when starting the truck, it goes up and down (between 2000-2500 approx.) then it idles fine but will die after about 2 minutes of idle. I tested my IAC and TPS with a multimeter and they seem to be in good condition, but when I unplug the IAC the truck runs better, no rough idle.
I changed the fuel filter and the spark plug cables.
Any idea of what it could be?
Thanks
Clean the IAC and its ports.
The shaft and the piston that slides on the shaft.
Whack it against your palm, repeatedly, making a thwock sound.
I use Seafoam.
