Lindy
- Jun 2, 2013
I hope someone here can help me. My 1988 B2 4x4 manual has been in the shop for a couple of months. The guy has tried everything he can think of and I picked the brain of another guy too. The problem is she starts fine; but if she's turned off or cuts off (because I mess up with the clutch) she won't re-start. She has to sit for awhile...10 or 15 minutes maybe...and then she starts again. Here's the background:
She's my #2 in the rotation. I use her for hauling and bad weather. In fall of 2011 I replaced the battery. By Feb 2012, I had to jump her 3 out of 5 times to start. I thought something was draining the battery, so I took her to the guy. We decided rather than waste time and $$ trying to track down the problem, he'd put a kill switch on her so I could disconnect the battery when I wasn't using her. He also noticed the battery was a little smaller than it should be. Took the battery back, sure enough it was a little smaller than the book says it should be so I got the bigger one.
I went to pick her up and he had her running. He turned her off to show me how easily She would start after the fix...and she didn't start. In hindsight I see this as the beginning. He thought it was a starter problem, so he replaced the starter. For some reason (can't remember why) the alternator was replaced too. I picked her up and took her home.
Drove her very little with no problem...probably because I didn't turn her off for short periods. Noticed the tailgate wasn't closing properly, causing the interior light to stay on...really annoying! So I took her back to him. As I was backing into the garage, she cut off. When I tried to start her again, she wouldn't start. I remembered that once before that, I was backing up at home, she cut off (both times my problem with the pedals) and wouldn't start. That's when we decided there was a problem.
Since then he's put on two more starters (thinking that was the problem) and I think he said he connected something directly to the battery. I also told him that another guy mentioned a possibility was one of the poles (?) in the solenoid might be corroded.
I haven't talked to him for awhile. She's sitting at his place and I guess he works on her when he has time or has a new idea what the problem might be. I'm looking for ideas I can take to him.
Since I'm thinking the kill switch is when everything changed, I wonder if reversing that would fix things. But then it seems I'd be faced with that battery draining problem again.
Everybody wants me to get rid of her. I'm not ready yet.
If the engine blows or the transmission falls out...fine. But I'm not going to let her go over some mystery ailment.
Any ideas will be appreciated. I'll take everything to the guy.
Keeping my fingers crossed.
Thanks in advance.
ETA...Should add when trying to start after she cuts off, it sounds like the problem is a bad battery...rrrrrRrrrrrRrrrrrR--I think. Truthfully it's been awhile since I've heard it. But the alternator is working fine. Took her to a parts store, they checked the battery and said it was fine.
Thanks in advance.
