B2 floor shifter to AOD
Dishtowel
August OTOTM Winner
OTOTM Winner
Grande Prairie , Alberta, Canada
So, I have to rig my floor shifter to my AOD. Innitially I thought I would pull the shift arm off the transmission and build a new one of the correct orientation and whatnot to co-operate with my B2 floor shifter. The shift arm on the AOD dosn't want to come off.....
So, what have you other guys done? Is there a proffered method that I have missed picking up floating around the forums here? Is there a kit that I can obtain to make this easier?
Thanks for your input.
You need to remove the oil pan, to remove the sift arm. On my Ranger i've installed a floor shifter to my AOD. I've removed the floor shifter, shift cable, and bracket from a junk car. I've clamp the shift cable end bracket tu my shift arm with vise grip and try if all cooperate well. make someminor adjustement and welded the piece together(don't let the shift arm come to ho or you will burn the seal, weld a little, cool th shift arm, weld a litlle , cool.........)
Hope this could help a bit
Thanks very much! If I can get the shift arm removed then I can probably rig up something to my taste!
I should have done that when I had the entire transmission disassembled! :S
