B2 bogging
headhunter257
canada
had a 87
had a
my bronco 2 is now bogging
to me it seems like lack of air it will run good for 10 min then start bogging at 3000rpm and then slowly start bogging down till it dies wait 5 min then she runs fine again any ideas thanks
Sounds a lot like a busted TFI ignition control module. Search the tech library, if you have a multimeter, you can test it. Some parts stores can also check one at no cost before you dump the money in a replacement.
If that's what it is, you'll wanna grab the $5 tool that has the thin-wall socket that fits the bolts on the ignition control module. Trust me on that.
thanks i will try that right now i think it also might be the intank pump but would not understand why i just bought the high performance one cuz i dont like doing things twice could i have hit a bump to hard and knocked the intank pump out of wack just an idea
