Axle Seal Replacement + Other questions
Alex98
Alright I posted a while back on doing a explorer axle swap, which is done. Have everything up and running except for the ebrake cables I know it has to be done a bit differently from the stock cable setup but I don't know exactly how to set it up. It's not really in the guide which btw is very good and detailed. To anyone who has done this what are your suggestions to getting it up and running. Pics are appreciated.
My front passenger seal is leaking quite noticeably. I have the replacement seal and have done it on the driver side, but on the passenger side in the cv joint using a regular "seal seater" won't work because of a small shaft sticking out of the d35. Is that removable? Simply just use something to seat it with a larger inside diameter as to not hit the shaft?
All suggestions/advice thanks in advance.
