lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- 5.0L
- Automatic
- Total Drop
- 4”
So I'm finally swapping to a D-35 in my choptop. It's past time that I do. And while it's sitting on the ground next to the truck, I figured that now is the time to do a rebuild on it and squirt some paint.
The axle is a D-35 out of a 93 Explorer. The rubber pivot bushings were shot (the ones on the axle beams - the ones on the radius arms were too, but since I'm going long-arm, there is no worries there). I tried forcing them out, but no go, so I hit them with the torch and cleaned them out, leaving the pivot sleeve. Then I picked up some new poly bushings from James Duff.
I went to install my new bushings and discovered that the sleeve had rusted a bit, so I thought to knock the loose rust out of there before shoving the new bushing in.... and that's when the middle of the sleeve turned out to be nothing but flaky rust and disintegrated on me....
I'd rather not have to buy new bushings with the sleeves if I didn't have to. Is it possible to buy just the sleeves for cheap?
My other thought was to fill the center where it's rotted out with fiberglass reinforced body putty... the two ends are in ok shape, just the middle that's gone. Any thoughts on that?
And for my other question.... while I have the axle out and using the welder for building my long arms... is there anywhere I should add reinforcement to the beams? I'm not planning on using the thing as a hard-core off-road truck or rock crawler, it'll be a streetable wheeler that I'll play in the dirt an rocks with but don't want to smash up the body. I did, however, trim the axle shaft window in the passenger side beam a little larger though.
