CountryBoy704
OK so this probably belongs in the axle thread BUT I want answers from people with fabrication experience so here goes.
just going to throw some thoughts I have out there
My backyard 8.8 swap is wearing both rear tires heavily on the inside = the housing is bent with the pumpkin low and the tubes are cuving upwards to some degree?
This is probably caused by welding with too much heat @ the perches and shrank the top of the tubes somewhat causing them to turn upwards?
I can possibly fix this by simply heating the bottom halves of the tubes directly opposite where it was welded at to offset the compaction caused by the welds on top??
