Mack1100
- Oct 2, 2011
I have an 88 BII, 5 speed, manual shift transfer case, manual hubs, 3.45:1 gears.
I want to upgrade to a Dana 35 and 8.8. I want 4.10 differentials and a rear limited slip. I also want Explorer leafs and about an inch of lift. I am going to run 235/75/R15 tires.
Was the 4.10 LS common in the 91 to 94 Explorer ?
What is the best way to match the front to the same slight lift you get with the Explorer leafs ?
Are the BII front and rear shocks long enough for the slight lift I am looking for ?
If I end end up with an Explorer front axle that has automatic hubs, what do I need to convert to manual hubs ? Are the Warn manual hubs any better than Ford manual hubs ?
Will the Explorer front drive shaft be the right length for the BII ?
