Armatron
- Aug 15, 2007
If you're ever needing to do your ball joints and have coil spring front suspension (IIRC 98+ 2WD, possibly 4WD too I dunno) then the Duralast lifetime lower ball joints (with the grease fitting) DO NOT FIT.
Well, they fit - as in, they press in, and it looks like it would fit, but the rubber seal is too small. Water would very easily get into the 'sealed' area (there is about a 1/8" gap when the truck is level and at rest, so flying down the highway at 70mph in the rain would make short life out of the ball joint). I had to take everything back apart and replace them with moog (moog ball joints cost me a total of $20 extra, well well worth it, it's a MUCH better part)
I figure that there are a lot of guys like me that buy the cheapest lifetime warranty part from autozone, and this is a case where the part sucks. Wasted 3-4 hours of my saturday morning tearing everything back apart, then the autozone employee had the nerve to try to tell me I couldn't return it because it had been installed!! They gave me the wrong part! BTW - he pulled 2 or 3 different balljoints off the shelf and they're all the same way (both the sealed and greasable) so it's some sort of part # mixup in their system.
