- Mar 26, 2018
- Brighton, CO
- 3.0 V6
- Automatic
- My credo
- Friend of Bill W.
It's time again, another 30,000 miles, to change out the transmission fluid in my '02 4WD Ranger XLT.
As I recall from the past, in older Ford LTD's one could unhook the transmission to radiator coolant lines, start the engine, and pump out most of the transmission fluid. This prevents a face full of transmission fluid when removing the oil pan - since they no longer come with a drain plug.
I know this works with my Ranger because I used this method some years back before I installed a transmission oil pan with a drain plug.
My question here is will this method empty out the torque converter? I do know that just draining the oil pan will not empty the transmission.
