Illini_Rob
- Feb 20, 2008
- Automatic
Well I got my transfer box problem solved with my new old truck and now a transmission problem is starting to pop up.
1992 Ranger extended cab, 4.0 V6, Automatic, 4x4
The problem:
It's been in the 20's here in Illinois and my transmission has trouble shifting sometimes. The engine runs like a clock so I'm sure the trouble isn't there. The truck coasts just fine so I don't think it's a brake/drivetrain problem. I know I'm in 2wd mode because when parked the forward transaxle turns freely by hand.
When I start the truck up and immediately start driving the truck won't shift into higher gears. I end up doing 25mph at about 3000rpm. After about 5 minutes it will shift -- although sometimes abruptly. If I warm up the car for 10 minutes it will shift right off so it seems to be temperature related. Also, when driving at say 60 on the highway, what rpms should I expect with this engine/trans?
Any ideas??
Thanks in advance.
The problem:
Any ideas??
Thanks in advance.
