Auto-Manual swap
The_Dealer
Macon, GA
hey guys im contemplating on swapping in a manual from a 86 bronco II into my 85 with the a4ld, and i have a few questions. Can i buy a complete pedal assembly from the 5sp vehicle? or do i have to add the new clutch and brake pedals to my assembly i have now? also where can i buy the clutch lines/clutch master cyl for the new tranny? all the b2's around here have been raped of the good stuff.
what else would i need besides:
flywheel/clutch
slave cyl
t-out bearing
pilot bearing
pedal assembly
which would be the best tranny to go with to be an easier swap?
ok i found 2 different trans in my area, i found a fm145 with manual transfer case, and i found a few fm146's but they are a little more expensive. which would be the best to use to swap in for my a4ld and to retain the driveshafts i have now?
You're much better off with an M5OD-R1 from a Ranger with a 4.0L. It will have everything you need except new pilot and throwout bearings.
