nvrsunk02
Guys, noticed some wheel noise on the front of the 2002 extended cab 4x4 I just bought. Just put on new 265/75/16 AT's, and had a full alignment. Not sure if it is just tire noise or something worse. Chiltons says the bearings on this are sealed and shouldnt need servicing. Did notice that when I jack up the front and spin either tire that the front driveshaft spins also. Should that be happening? Not sure how an automatic hub works. Thanks!
