So I know the m5od calls for ATF, I grabbed a gallon of the Oriellys Autoparts all purpose ATF n a qt n a half of the original Lucas oil stabilizer, it says on it you can mix with ATF
I've seen what Lucas does to oil so is assume it's going to have a lot better lubrication
My m5od came out of a 92 ranger with 4.0
It's going into a 89 b2 with 4.0 tom so I need to know...
Has any one ever had a bad experience with Lucas in this trans??
Should I do it or no?
I also heard and absured thing about motor oil like 5w-30 or something???
Wouldn't the Lucas ATF mix be comparable if not better then motor oil?
