KENWIL138
- Aug 6, 2007
- Automatic
The truck is a 95 2.3L 2wd. 110,000 miles. I just recently started having this problem. I started the truck up one night and let it sit and idle and after about 3 minutes of idle the truck started running real rough and then died when I tried to give it gas. I never had problems like this before. I had already changed the fuel filter, pcv valve, plugs, and wires. I put the code reader on it and it comes back as a P0171 code, lean bank 1. I cleaned the IAC and the MAF. Do you guys think that I may need to replace the EGR valve or the one that controls it? Please help ASAP. Thanks.
