Kitcat
Once again I need to pick your brains. Is the power steering pump the same on a 4.0 v6 and on 2.5l ? I'm not talking about the brackets from the pump to the engine, just the pump it's self?
there is a pressure side hose difference in there...i think the sla is different later on late 2000's....but 90's iirc are all
Thank you for time and info.I would think since the Explorer used the same 4.0l engine 1997 pump might be OK to used, but Ford doesn't list it as compatible for Rangers
I can't say for sure on body parts but I would say no, because the Ranger had body changes in 1998
Basically there are 3 generations of Rangers in the 1983 to 2011 years
1983 to 1992, 1989-1992 had front clip changed, Gen 1 and 1.5
1993 to 1997 Gen 2
1998-2011 Gen 3
1993 to 2011 have many interchangeable body parts, just not sure about those parts you mentioned
4.0 is a 97 and the 2.5l is 98. Also is the body parts ( doors, complete grille and headlights assembly ) interchangeable?
Thank you for the infoI can't comment on the power steering pump, but 93-11 are more/less the same from firewall back - doors, box, dash, seats, etc. There are some minor differences, i.e. tail lights are only common from '93 to 00, but most of it is "bolt on". Firewall forward - fenders, hood, grill, lights, bumpers are all different between 93-97, 98-00, 01-?04? and ?04-11. Depending on your level of craftsmanship/how much you are replacing, it can be made work, it won't be a bolt on.
