Along with my 2006 FX4 , I own a 1998 2wd ext cab 4.0L with 190,000 miles. The stock rims on the 98 are 14x6 (225x70x14) and when it came time to replace the tires, I bought a set of 1998 stock 15x7 Ranger rims from craigslist.
The new rims came with 225/70/15 tires which were worn out and noisy, but fairly balanced. I ran these rims and tires for about a week.
Now for the problem. I went and bought four new Wrangler 225/70/15 tires and had them installed on the truck with the new rims. For the first couple of days everything was OK, but then the vehicle developed a bouncy sort of shimmy. The ride is smooth unless you drive between 60 - 75 mph, then the shaking will make you crazy. While the car is shaking you can see the passenger seat shake side to side and squeek.
So in the past two weeks I've taken the vehicle back three times for rebalancing and alignment, but no luck. During this time I have also replaced the u joints thinking I had a bad drive shaft. I tweaked all kinds of front end parts until finally I remounted the old stock wheels and tires I had kept. Like magic all the vibration stopped. So I took the vehicle back to the tire dealer and now he says the wheels I bought from craigslist are not lug centric and have a slightly larger center bore. (The new wheels were mounted with the same old conical lug nuts from the original rims) He says the new rims aren't centering up exactly because the aren't designed as lug centric. Now he wants to sell me new rims. Yeah, right.
I say he's full of it, but thought I'd ask here to see if I might have a screw loose. So, were there any hub centric stock wheels for Rangers, or, are they ALL lug centric. (?)
Attached you will find pics of my good 14x6 stock rims (with the hole pattern) and my chromie new 15x7's , both of which appear on the tech forum and are listed for 1998 rangers.
