are all 7.5 the same? 88-95?
mkpecor
black diamond W.A.
im woundering if a 1995 7.5 rear axle the same as my 1988,are the spring perches in the same spot? im going to buy a pair of axles with 4.10 gears ,front and rear out of a 95 ranger can i through those in my 88 and be ready to rock and roll ? i know it sounds stupid but i want to make sure it cool be for i drive 2 HRS and spend $140 on the set up.
'93up axles are 2" wider at the WMS. The leaf perch spacing is the same though and will bolt in to any earlier Ranger (however you'll need to swap or modify your rear driveshaft flange on your '88).
ya you can..but be quicker to swap the rears out....and also the flang swap is quick....10 min at the most
