AR15 Build
bump...
looking more into building my own. come on guys... give me suggestions.
would like to start w/ a lower.
i want 5.56. 16" barrel. simple build.
Suggestion? Buy mine.:thefinger:
You want to start with a lower? A lower is a lower is a lower. Find one with a roll mark that you like and buy it.
For an upper look at http://www.jsesurplus.com/ They usually have pretty good prices.
When looking at uppers/barrels think about what chamber you want.
For .223 there are 3 common chamberings.
5.56 NATO Chamber:
5.56 load is hotter than .223 Remington loads. A 5.56mm chamber is not as tight as a .223 Remington and will take the brass expansion and higher power load of a 5.56mm round. They are generally less accurate than a .223 chambered gun.
.223 Remington Chamber:
The chamber and throat are very tight and usually are more accurate. DO NOT USE 5.56mm Ammo in a .223 chambered gun.
.223 Wylde:
A hybrid of the .223 and 5.56 chamber. It has a slightly larger chamber and throat than .223 but not quite as open as a 5.56 one. .223 Wylde (IIRC) was made to shoot hotter loads in match grade guns. You can use either .223 or 5.56mm ammo in a .223 Wylde. A .223 Wydle is generally as accurate as a .223 chambered gun and more accurate than a 5.56 chambered weapon.
Then of coarse you have specialized chambers such as .223 Ackley Improved and wildcats based on the .223 such as 35-223, and 300 Whisper.
I run a .223 Wylde chamber.
-Jester
there's lots of good lowers out there.. check out midwayusa.com......they have a ton of different lowers and most have reviews.
i'm starting on my AR build when i get my tax return. i've decided on this upper:
http://www.midwayusa.com/Product/51...chrome-moly-matte-with-glacierguard-handguard
i'm gonna start with this lower (i think):
http://www.midwayusa.com/Product/35...d-with-6-position-collapsible-buttstock-matte
later on i'll switch out the trigger for a timney and probably get a new rail for the upper. i just want a basic rifle to start
There is a gun show here in Indy March 15, 16, 17. I might pick up an AR then. I am going with the 5.56 just bc that is what I was trained with and qualified on.
I just sent in 2 Form 1s Fingerprint reference cards and a 5330.20 form along with a sizable check so now just going to be awaiting ATF approval to put a BCM 11.5 inch upper on my AR
i get my Patriot Defense Arms stripped lower on March 3rd.
did a group buy w/ some local folks...
trying to figure out where to go from here... do i wanna buy a complete kit minus lower and just put it together? or do i want to buy it piece by piece. I think at my knowledge level i will get a kit...idk.
Make 'em yourself, I see people do it all the time on the tv :icon_twisted: :D
To me, the point of building something is to combine parts you can't get in an off the shelf package.
Knowing nothing about it I would rather peice it out with more optimal stuff if I was going to take the time to "build" it myself.
Maybe if you can get what you want in a kit for a decent price it would be worth it. I do know when it comes to things like say engine swap kits you get a bunch of medeocre stuff that accomplishes the task but you can do much better on your own for a lot less $$.
Research is key so you know what you want, what you can afford and what will work with what... and that is the funnest part of a "build" for me.
I think part of me wants to get a kit so I can have it done quicker.
just get a complete upper, a buttstock and trigger assembly and assemble it from there
that might be the plan. think i might order my upper here in the next few days.
might pick up a lower parts kit from PDA when i pick the lower up.
i found a completely assembled lower (collapsible buttstock and some sort of generic trigger) from midway. i was thinking i'd get that and then find an upper to put on top. it would be a decent gun for $500-$600, i cant remember how much each was so it could be more like $650.
i'll probably switch out the trigger eventually and get a nicer buttstock
If you decide to scratch build you will need, at minimum, a receiver clamp, a barrel nut wrench, some roll pin punches, and, if you are doing a collapsible stock, a stock wrench. You will also need a bench with a vise.
One thing I do to all of mine is to true the front of the receiver where the barrel installs. Brownells sells a tool which amounts to a lathe-turned bar with a shoulder on it where you apply lapping compound, insert the lubed bar in the receiver, then turn the shoulder against the front of the receiver - you can use a drill, but I just turn it by hand. This will correct any out of square condition that may exist due to the pulling of the aluminum by the threading die.. I have found this to be a cause of barrels being mounted pointing off to one side slightly, and requiring lots of clicks of windage to zero.
Featured Ranger Based Vehicle
