HoleshotKFX400
First question is, Do you need to hook up the TV cable on a AOD trans? If so do they make kits to adapt it onto a carb'd motor?
use a guage on the TV port and set it to 10 at idle. make sure it rises as soon as you give it gas. if it shifts to late for you then back it down a couple psi. make sure you at least have 4 or 5 psi at idle though. the more you run the better on the trans
you're talking about with a 1/4 inch spacer in the cable. when you take the cable out, it should be like stated...around 5 but more than 0. i like to run more. it wont hurt,it will actually be better on it,and it shifts better and downshifts easier30-35 PSI at idle in neutral. Any less than that and the trans will die a horrible and expensive death.
