AOD Swap
!1995Splash!
Morenci, Michigan
Last weekend I purchased a 1995 Ranger Splash for $100. It has a 4.0l with a 5 speed. The motor is seized and I have a 302 with AOD out of a 1983 crown vic. I want to swap them into the truck. I was wondering if a AOD will fit in the truck and what would be the best option as far as getting a new steering column with a shifter on it or get a floor shifter for it. I am new here and if there is a thread about this already, I am sorry, I didnt see it. Any help would be greatly appreciated!
Welcome to TRS
That is a very labor intensive idea you have there. :icon_welder: Whys not just stay with the manual trans?
I imagine you could use a factory automatic shifter steering column and make it work with the AOD. The column has a cable shifter assembly so you wouldn't have to make linkage or anything... possibly just a bracket on the trans. Probably could use a floor shifter too. I think there was one made for an AOD that looks like a manual trans shifter, saw one in an F100 a while back. Pretty cool.
But they do it, for a daily driver it's probably ok. finding a m5 r2 would be easier also, But to go over to the dark side (automatic) is a monster job!
I was reading that the M5OD-r2 wont hold up to the power of the 302.
Considering that the R2 was used behind the 302, and the 4.6L which makes more power stock for stock, what you read was
cow-feces-picture-id502450654
Yes, AOD will fit
Column shifter doesn't have indicator on the column its in the lower instrument cluster which can also be swapped in, 93/94 cluster would also have mechanical speedometer for AOD use, although you can use speed sensor on the AOD for the 1995 cluster
Floor cable shifter may be better option
Big thing with AOD and carb setup is the TV/kick down cable, it must be adjusted correctly or you will burn out the trans.
Hmm the r-1 was the stock manual transmission and Rangers wasn't it?
I just can't wrap my mind around changing a manual truck over to automatic, I mean it's bad enough changing an automatic over, which is why I sold my other one and got a truck that already has manual in it.
R2 is the heaver duty manual and was used in the F-150's with V8s up to 2008
The 1997-2003 F-150 with 4.2l V6 also used the same M5OD-R2, AND.........the 4.2l V6 has exactly the same bell housing pattern as the 302 :)
Also the shifter placement in these years is only 1" difference from the R1, so fits nicely in a Ranger
The R2 from the 4.2l does need the bellhousing bolt holes reemed out, about 1/16", because it used Metric shaft bolts, 302 used SAE bolts
But there is a down side, speedometer interface
My '94 Explorer came with a 5 speed and I have replaced it with a C5 auto.
It all comes down to what you want - in this particular case I was going to use it for offroad racing... and sure you can use a manual, lots of guys do. But just driving is a lot of work, physically and mentally, with the auto you have instant power when you push the gas pedal. I think it's an advantage. And I had everything to do the swap for free.
I'd have no problem replacing a manual with an auto as long as it's not an A4LD!
My bad apperently the transmission in the truck is a M5OD-R1HD. would that still hold up? The trans has 256,000 on it
The 4.0 and the 5.0 don't have the same bellhousing bolt pattern, and the m5od doesn't have a removable bellhousing. A 97 to [I think] 03 f-150 came with a m5od-r2 that will bolt to the 5.0. You need to find the 4.2l or 5.0 engine option in the f150 that the trans will come out of.
waaaa l wanna R2! [emoji56][emoji32][emoji3525][emoji848]
My bad, I went back and looked and according to what I found it's a M5OD-R1HD. It said that's what was put behind the 4.0l. The engine isn't staying stock either though. We are planning to build the motor a bit.
