Mine does not have that. The kickdown is a rod. It does have a 4 wire connector coming from the tranny however that I do not know where it goes.
Is the plug on the left side of the tranny? Never seen one with a rod but I would like to get a look at it. Sounds easier than the way mine is set up.
So my truck has a c-6 and it gets 16.6mpg and I have an aod thinking about swaping with the c-6 but the aod is computer controled right? Would I need the harness and compuuter from the donor or could I make my cruuent 89 5.0 wireing work? Thanks a lot guys
Make sure if you get the AOD you get the slip joint to go with it. Its an odd spline count and it only fits the AOD from what I know
