I am running an AOD behind my 5.0L. It is build quite stout (from Performance Automotive and Transmission Center) with wide ratio gears and a 2500 RPM stall converter.
The problem is, when I am going slow (on or off road), the trans climbs through the gears way too fast. It can be in 3rd at 25 MPH. With a heavier throttle, it will hold the lower gears longer (and shift firm/hard.)
Is there any way to slow the upshifts at partial throttle?
