Anyone Upgraded to LED Headlights for the First Gens?
What I did:
What I did:
I do feel like the Hella len assemblies are high quality. Just by "looking" at them. Do they justify the higher price, I don't know?
It was literally plug and play.
I have no doubt Hella is better, Holley makes drop in LED assemblies that are supposed to be really nice too.
What I have is better than a sealed beam though. :dntknw:
100% on that last point.
I had considered the Holley LED drop ins, but a little pricey.
I felt like I've been driving with old Mag lights were half the battery is on its way out. Now when I pulled up behind the cars in front of me on the way to work, it illuminates the back of that car.
I'm good with halogens, can usually find a bulb somewhere if you get in a pinch and have enough light.
My 2017 F250 Lariat has Halogens which I much prefer over the thought of ever having to replace a Ford LED assembly. It has great light output, but also uses 4 bulbs in total even on low beams.
  • Like
Reactions: gaz
If I have to with mine I can run normal bulbs too which I kind of liked.
I am kind of on the fence with Halogen vs LED, the lights on my 2016 F-150 seem to carry farther and spread better than either these LEDs or the LED's in the Bronco.
I like LED better, but you have to be careful about the light output so they're not to bright.
Those round headlights I bought are meant to be a stock replacement and have a 3000 lumen low beam and 6000 lumen high beam.
@RobbieD @Hoosierman
I still haven't aimed them, but they are aimed where the old sealed beams were.
Figured while on a dark county road would be the best test.
First is regular, second is the brights. Pretty dang good in a first gen for halogens I think.
  • Anyone Upgraded to LED Headlights for the First Gens?
Thank you. Very good pics; helps a lot.
What size are the lights?
I have spent all day working on a tech article discussing the different ways to add LED headlights, and what I quickly realized is that all of these companies are full of crap when they list the lumen ratings for their LED bulbs. The only company that I have found that rates their lights truthfully is LASFIT.
For an LED, Lumens = Watts × Luminous Efficacy (lm/W)
Standard LED: ~80–100 lm/W (Example: 50W x 100lm/W = 5,000 Lumens)
High-Efficiency LED: 110–150+ lm/W (Example: 50W x 150lm/W = 7,500 Lumens)
In the ad below, it's not possible for a 40W light (or dual 40W lights) to put out 46,000 Lumens. You'd need 460 watts to put out 46,000 Lumens. Even a really highly efficient LED would still require 306 Watts. Two 153-watt High-Efficiency LED's might do it.
I saw ratings for 9004 LED bulbs that ranged from 30,000 Lumens to 70,000 Lumens. 🤦‍♂️:shok:
UPDATE: I finished my Tech Article for anyone interested:
About 18 months ago I replaced the old sealed beams in my 1987 Ford Ranger with these units by LEDMIRCY through Amazon and I love them! https://www.amazon.com/dp/B08DFYDPXH?tag=959media-20
With my old sealed beams I couldn’t even tell if they were on half the time in town, and I even tried replacing them with new Sylvania Halogens (std) with no improvement. These LEDs have a better spread and carry much further. They were as simple to install as the old sealed beams and are still working great and were only $31.22 for the set, (they are DOT, CE and RoHs approved).
I will also add it might be time to do some small electrical projects/upgrades.
I'm running the original alternator and external voltage regulator. I would like to upgrade that.
I do think it will likely be worth while to wire in relays for the lights. I noticed when I turned the heater fan on high I could see the lights dim ever so slightly.
  • Like
Reactions: gaz
That seems to be the case with a lot of things. I run R/C crawlers, and you have to look past the hardcore brand-loyal individuals, paid ads, and marketing documentation. You start to see that, while a lot of companies claim to have an edge, really they're just repackaging batteries, or buying from the same suppliers. All their C rating claims are false, with one or two outliers.
Featured Ranger Based Vehicle
