Anyone parting out an '88 2wd 2.3 5 speed truck?
turbo91xlt
RBV's on Boost
Goshen, NY
1992
Looking to purchase several parts from a 1988 Ranger to ditch the boat anchor 2.9/a4ld in my '88 GT and drop a 2.3t 5 speed in it.
-Complete clutch pedal assembly with neutral safety switch and hydraulics (believe this to be an '88 only part, something to do with the safety switch). Have 2nd gen pedal assembly I could trade also..
-4 cyl 2wd engine mount brackets that bolt to the crossmember ('85-'97 should all be interchangeable)
-Complete & clean '88 2.3 EFI engine wire harness - no cuts or splices ('85-'87 may work but I'd rather start with an '88 harness)
-Uncut 2.3 EFI fuel lines (should be the same '85-'88)
If anyone has a complete '88 2.3 5 speed 2wd ranger in the lower NY/NJ/PA/CT area for cheap I'd consider purchasing the whole vehicle for parts.
Have a bunch of RBV parts to trade too, just ask me what you're looking for.
Thank you, Charles
Found a complete, running '88 extended cab 2.3 2wd 5 speed ranger local for cheap I'll be picking up tomorrow.
