Anyone have pics of a 98-2000 with 2/3 drop and 20's?
flyhighb
I have a 98 single cab with a 2/3 and 18in wheels. I was deciding if i should put 20's on it or lower it 4/5 and leave the 18's. thanks
here is a pic of it now 2/3 with 18's
Go 4/5 with 20s
SVT
I cant afford it right now or i would ha...i can get a good deal on some 20's but i want to see what it would look like with a 2/3
Here is my 96 with 7/9 on 20's
SVT
cool thanks for the opinons. I think im going to do the flip kit this weekend because i still have the old 2/3 drop that came with the 2 spring pack for the rear. Plus i can get it a inch lower in the rear.
what series tires? 225/40/18 with a 4/5 drop???
What size tire are you running on those 18's? And what is the offset? I'm going to be doing a 4/5 soon and I am trying to get a handle on what size tire I can run. I would like a 45 if I can. Not looking to go with a 40 if I can help it
flyhighb,
First off, your trucks paint looks mint! I like the way the 18's look. 225/45 18 is what I am going to try with a 4/5. Do you have any rubbing now? Also, what offset are you running on those wheels? Are those the eagle alloys you showed me in another thread?
Gary,
Thank you! I actully just wet sanded it then buffed it with rubbing compound and then waxed it. No i don't even get close to rubbing,i could run larger tires if i wanted. Yes these are eagle alloy's also but not the same ones. Im not sure on the offset of the wheels.
