- Nov 30, 2001
- Gnaw Bone, Indiana
- Manual
1/4"--an angle grinder with a cut-off disk. A band saw is only good for cut-off work. And I only like it because you can set it up and let it work while you do something else. If you are in a rush, the chop saw or angle grinder are faster.
Metal work doesn't need much precision. Welds are FAT. When it exactly matters, like bolt holes, you bolt it to a jig before you weld it. Even a wooden jig works. I have a series of shotgun racks I built with a wooden jig and it is blackened, but still great. With 1/4", you need a 220amp stick welder. You don't need a TIG for a bumper. Grind a bevel if you are worried about penetration. Or even if you aren't.
