anyone ever try this?
PaleBlue90
Solid Axle Swap
RBV's on Boost
Aurora Colorado
ok so frist off i have my 89 ext cab, it has a 2.9 v6 and a 5spee with a manual tcase. well i kno the d28 is crap. i have a tj d30. if i get shafts for it,rig up control arms,get a drive shaft made, use zj coils and get a manual hub conversion could i make it work with my rangers stock case? the 30 is out of a 02 tj. its open/with 3.73's. sound good? anything i missed?:icon_welder:
look in the tech library, theres writeups on them.....
the bII is on the back burner, im putting together the ranger, thus the great ranger part sell off i got goin on, im able todo my original plans for this longbed once again cause fate has brought me back my old ranger :)
I woudnt put the 30 in anything. I have on in my Heep, and as soon as I have the cash, its getting 60's front and rear. No sense starting out with a weak axle.
my thoughts exactly, tradin a d28 ttb for a solid d30 is like tradin herpes for aids
The 95-up D30 it pretty much as strong as the D35...
I though you already had an SAS truck paleblue?
I like to compare it to trying to polish up a nice steaming turd.
na. polishing a terd would be getting moly axles made for the d28, puttin a brand new locker in it etc....
I have moly axles in my 30.... that's just becuase the PO put them in.
if ur gonna put in a d30 why not just get a d44 and shorten one side 6" poof, u can use a eb axle in that side and its CONSIDERABLY stronger then a d35 or d30. sure its a little bit more work, but u wont have to upgrade when u want to run bigger then 33's LOL
Same U-joints as a D35, sooo much stronger :rolleyes: The bigest reason for the D30 is the matching bolt pattern, width and mounts for suspension links.
ya, they are so much stronger, everyone always says OHHH smae u joints, well guess what, the u joints in a solid axle are nowhere under the same stresses as those found in TTB trucks. can u buy moly shafts for a ttb d35?? can u upgrade u joints?? dont get me wrong, i know the ttb 35 is a stout axle, but really, id rather have a solid axle up front that i know isnt known for blowin with 33" tires (like d30's)
duno why everyone dogs the dana 30, i see them in XJ, wranglers all the time with 35s + and they seem to hold up fine, basically any axle with a lead foot is gonna break, just a mater of time, and the dana 30 is a good, cheap setup to get a SAS started, and dosent the dana 35 have more than 2 u-jounts, thats atleast 1 more part to fail
