Anyone ever built a BII "sport truck"?
MountainMike
Canada
2"
31"
The fun begins where the pavement ends
It's just something I've been thinking of. I see from time to time people building little regular cab short boxes into track toys and was wondering if someone had ever done this with a BroncoII. After building 2 trucks I'm starting to think about building something sporty, a little car of some sort. But I think it would be cool to see a BroncoII lowered with some performance & chassis mods. Maybe a Ranger GT-esque ground effects kit. Anyone seen anything of the like?
I saw a lowered one that might have done ok if it wasn't a frame-dragger. It would have no room for body roll.
It's in Jim's "I bought a B2" thread.
I've seen a couple slammed ones too, I just haven't seen one usefully lowered. To improve GO instead of SHOW.
no, i haven't. yes, i would like to. get to it!
Honestly, a 3/4 drop for a Ranger and then play with spring rates and sway bars. Just gotta do the math.
I agree, it would be cool to see a BII sport truck. 4.0 swap first gen, and I've seen one around here, a 2nd gen, with what looked to be a factory ground effects kit. I think it would look cool! Probably 2WD front beams and leave an Expo 8.8 as spring under. Starting point anyway. :dunno:
Just don't slam the thing do the ground, it would look horrible... and I would negate the ground effects too, save those for the ricers. Just make it into a sleeper car, big V8 in a regular looking BII.
I've been thinking about it that's for sure
Basically that is what I was thinking.
like nancy ragen said just do it... never mind that was nike that said that but she should have said it:icon_thumby:
Sounds like a neat idea. You should work on one once you finish up Jammer.
go to broncoii.orgs main page, theres a gray colored one on some 17 or 18's, looks good. ive searched and search but couldnt find anything else on it
widening the track width by a couple inches usually has a better effect on handling
than slamming it to the ground, which forces the use of smaller tires.
Don't automatically ASSume that wider tires that have shorter sidewalls
will make a vehicle handle any better either...
those short sidewall high pressure tires generate NO traction at all when they are bounced off the ground...
AD
Hmmm, I was thinking about this earlier today... If you ran a set of equal length F-100 I-beams and some fiberglass fenders, I think you could really have something on your hands...
Don't need equal length beams. Just go with a set of F150 lowering beams.
I was planning to do something similar but it ran out of steam and the project was Junked.
