Well, at this point I'm only guessing. But I'm still trying to diagnose the mis-fire in my truck. I ran out of ideas long ago, and short of an engine rebuild, I'm running out of options.
I *thought* the slight miss was caused by a faulty O2 sensor on the driver side manifold. Replaced the sensor, it runs better but still not like it should.
The only symptoms I can give you, is that the engine is misfiring, but the computer doesnt even know it, its not kicking a misfire code. Runs a bit rough at idle, and smooths out after I give it some juice, but you can still hear it. It used to be that I could fill the gas tank, and it would quit misfiring until it hit around 1/2 tank, but that doesn't work anymore.
The only thing I can think of that I haven't tried yet is the injectors or the fuel pump. Neither of which makes sense. But as I said, only stabbing in the dark at this point.
