- Aug 6, 2007
- Age
- 42
- Orlando FL
- Automatic
I love my 05 f150 with a 4.6 have 30k on it and get about 18-23 mpg. the 5.4 and 6.8 had the plug problem.
Check the rear spark plugs.u can get new ones in work truck trim right now for dirt cheap!! but id like to know a lil bout the 4.6 micro v8.
mainly reliability and major flaws
My brother could not reach most of the plugs in his extended cab F150.
The mechanic said one came out with the aluminum head treads
Had to put a heli coil in.
In my experience there really isn't a reason to use antiseize on plugs unless its an aluminum head.
Early f150s with the 4.6L had a flaw with the motor, basically the valve guides go out, most of the oil in those engines are held in the head area, when the guides go out, all the oil is pulled into the pistons burned off, and kills the motor flat dead. I have a 97 with that problem sitting at my shop right now. there is an upgrade for them, and later models come from the factory that way.
