Any new firearm purchases?
i would think if a person wanted to fire 22lr through an ar, it would be cheap enough to just buy a rifle for 22. i know it does dirty up my little 22 revolver.
i have a question for you guys about ammo.
22 has a little ridge around the bottom that i guess keeps the shell in place when firing but some rounds are smooth all the way down. how do those smooth ones stay in place and not go into the barrel or firing area to much?
something locks around that necked down spot to keep it in place?
You're refering to rimmed, and rimless cartridges. To answer your question with the example of 9mm or .45ACP, the cartridge seats fully forward on the mouth of the case (the crimped lip around the seated bullet).
The rims on both rimmed and rimless cartridges serve several shared purposes. In a rimfire gun, it has an internal cavity with priming compound to ignite the powder charge. Otherwise, they serve as a purchase point for the extractor to hold the cartridge in the breech face, and for extraction. It is also (usually but not always) the surface the ejector acts on to expel a fired case or live round from the chamber.
There is also headspace that comes into play, as mentioned. Headspace properly defined is the distance from the back of a fully seated case, to the breech face of a fully locked breech, with the locking lugs fully seated against eachother.
To put it simply, picture this: There is a tiny bit of wiggle room between barrel, cartridge and bolt. Become a ghost for a second, and reach into the loaded gun. Push the round fully forward and the breech block fully rearward. That space between (often between a half thousandth to a couple thousandths of an inch) is known as headspace. Rimmed cartridges typically seat in the chamber, or headspace, off the rim. Rimless cartridges typically headspace off the mouth (or opening) of the case. Bottle neck cartridges are usually but not always rimless, and headspace off of the shoulder.
There are also cartridges that headspace off of both areas, in both categories. A rimmed bottlekneck, such as .30-30 win, or 7.62x54r, headspace off the rim AND shoulder. .300 win mag is a type of rimless cartridge known as a belted magnum. It headspaces off the shoulder AND the belt.
For the order of when and why they both exist, we go back in time. Your cowboy guns, such as single action revolvers, and other straight wall cartridge arms are all rimmed for the most part. It isnt untill self repeating (semi and auto) firearms come about that rimless really takes off. In tube fed arms such as lever action rifles and pump shotguns, the rim serves for feeding, allowing a pair of timed interrupters called cartridge stops, to easily regulate when the rounds come out of the magazine tube.
When box mags came around, the rims got in the way, as the stacking of those rims requires a huge curve in the magazine. Those old rimmed cartridges arent entirely gone however, the Russians still use the 7.62x54r in their belt fed PK series and box fed SVD marksmans rifle. It actually holds the title for the worlds oldest smokless powder military cartridge still in service.
Delving deeper into headspace and the why behind it, and why you should care about it. . . The small amount of wiggle room is critical. It must be both
A. Big enough to close on a round when the gun has powder fowling in it.
B. Small enough that the expansion of the case under firing pressure does not batter the locking lugs of the action, or allow the solid portion of the case to move too far out of the chamber to contain breech pressure.
If headspace is too big, headspace will grow over time. This USUALLY (not always) leads to misfires, as the gap between the round and breech face increases, eventually the firing pin doesnt protrude far enough to detonate the primers. It CAN cause case head seperation and/or popped primers. What that is is when the cartridge expands so much, that in the headspace failure's case, the pressureized gas cuts the case head and the case neck free of eachother and that atomized brass case or popped primer (steel, plastic, aluminum, whatever) is sent through the action under pressure to the tune of between 20 and 65 thousand psi. Unsupported brass can liquify to an extent under that kind of pressure.
Modern firearms are designed to vent this kind of failure away from the shooter in a controlled manner, however it is not fail proof and THE REASON why safety glasses are preeched so hard. If your gun explodes, the glasses are not going to stop the bolt going through your skull. True. Those instances are verry rare. Headspace breech failures such as popped primers and blown casings are much more common and guess what? Brass and aluminum arent magnettic. So the doc whose job it is to fix your eyes has to dig for it if you weren't wearing eye pro. Have fun with that.
There are signs to look for in your fired cases. Periodically compare your casings to those of live rounds. Do they exhibbit bulges at the base of the neck near the case head? Distorted shoulders? Stretch bands at any point along the neck? Backed out primers or firing pin indents that are inflating back into the pin bore? The most common sign for .30-30s are backed out primers, due to the lower pressure nature it doesn't typically display stretch marks.
There you have it. More than any of you ever wanted to know about the breech/cartridge relationship of a firearm.
TLDR, know your guns, periodically inspect your fired casings for abnormalities, do your research for abnormalities and wear your #$%&ing eyepro.
That was my experience:
Heh. Yea. That one had some issues alright. Ill keep reading your thread to see how it went from there. The marlin pattern action is the most commonly coppied lever gun of that design erra. I prefer the win 94 action. The win 94 almost never comes out of headspace. When it does, (I've only ever seen two) its a pain in the but to fix and requires major lathe work that I'm not going to explain here. The marlin action is very easy to put back into headspace several times in its service life before it requires lathe work and reset, but they come out of headspace all the time and cant hold nearly as much pressure as a win 94. The double edge sword lies in the locking block/breech bolt design. Due to the wedging angle of the locking block, working the action to raise it farther will decrease headspace, making it easy to correct. The problem is that the locking block is round and the hole in the receiver stretches and ovals through wear, causing it to sit farther rearward than it should. They're cheaper to make is why they're so popular compared to the win 94. The 94 has tripple the service life. No contest.
Heh. Yea. That one had some issues alright. Ill keep reading your thread to see how it went from there. The marlin pattern action is the most commonly coppied lever gun of that design erra. I prefer the win 94 action. The win 94 almost never comes out of headspace. When it does, (I've only ever seen two) its a pain in the but to fix and requires major lathe work that I'm not going to explain here. The marlin action is very easy to put back into headspace several times in its service life before it requires lathe work and reset, but they come out of headspace all the time and cant hold nearly as much pressure as a win 94. The double edge sword lies in the locking block/breech bolt design. Due to the wedging angle of the locking block, working the action to raise it farther will decrease headspace. The problem is that the locking block is round and the hole in the receiver stretches and ovals through wear, causing it to sit farther rearward than it should. They're cheaper to make is why they're so popular compared to the win 94. The 94 has tripple the service life. No contest.
I think the problem with my rifle and all its iterations as they tried to fix it was that Remington was simply building them in the basement at their New York factory with the lights off while wearing oven mitts. If they couldn't make a 336 they don't have a chance of making a '94.
Both have their advantages, I liked the simplicity of the 336 as well as the fact that the '94 being out of production it isn't really possible to buy a new one and at the time a really beat up '94 cost more than a new 336C.
Yea, they command their price. The ones to get cheap are the sears 94s. They were still made by Winchester post 64. Pre 64s are spendy. The Marlins made by Ruger went through a similar phase, albeit much, much shorter and not nearly as consistent of an issue.
I bought a really nice looking Marlin 336Y for my kids to shoot deer with a while back. So far they have been unsuccessful but I don't think that's the gun's fault. I haven't had a single issue with it and the fit & finish are great for what I paid (about $300, lightly used, IIRC.) I think we probably have about 200 rounds through it so far plus whatever before us.
Speaking of lever guns, I bought a Rossi 92 in 45 Colt years ago - beautiful gun - but my gawd it is a pain to take apart and clean. Some of the metal pieces showed what I would call very premature wear after only 100 rounds or so. It still works fine, just a bit disappointing. Anyone else have one of those?
They dainty little thing they use for a safety always scared me on those, it looks super easy to break.
They can be a pain if you don't know the sequence. Rossis (and Brazilian guns in general) have always had inferior metal/metalurgy to most other stuff. Depending on age their metal and heat treating have improved significantly over the years. Especially over the last handfull of years based on what I've seen. Fitment on Rossi stuff is middle of the road and most of their stuff has to wear in. It eventually gets to a point where the gun is happy, and it usually doesnt cause many issues with a proper cleaning regimen.
Its required for import and not part of the original design. You could take it out and never know the difference if you treat it like any old Winchester hammer rifle. I've actually seen one deleted before. Whoever did it did a pretty decent tig weld and surface grind before reblue. I don't typically ever allow customers to delete safetys though unless its a ground up build with new parts.
It very clearly has a "crap we forgot about the safety, quick come up with something... anything so we can get this to production!" look to it.
Its more of a "we have the technical data package for this exceptionally well designed gun but to sell it in the US we need to add a thumb safety. Do it in the least invasive way possible", translated to Portuguese, kind of thing. Their .22s have the ugliest crossbolt safety I've ever seen.
We sold a couple last week. My Winchester 190 .22LR and Brittney's Smith & Wesson ultralight .38.
She bought a Rough Rider to replace it. Hasn't even fired it yet.
I'm seriously liking the look of a Tippman M4-22.
Just gotta save up the money for it.
Those are pretty good from what I've heard. Between it and the H&K 416 22 made by Walther, those two were the customer favorites where I used to work.
There is a good number of ways to skin that cat. Rimmed cartridges, like the 22LR and .45 Long Colt use the rim to set the depth the cartridge goes into the chamber and holds it in place.
Straight walled cartridges with a rebated rim, like the .45 ACP, uses the front of the case to set head space.
Cases with a taper use the taper to sort of wedge it in place and hold it. Think 9mm Parabellum and bottle neck cartridges like .308, .223, and .30-06.
Some cases have a raised ring of metal somewhere near the base called a belt. On those, the belt sets headspace.
There are others that I'm probably forgetting. The above is the most common ones.
I'll second the Sears branded 94s. That's what my 30-30 lever is, Sears Ted Williams Model 100. Impossible to identify the date on the sears guns, but it is definitely a post-64 model 94. Was actually a freebie. Back in the late-90s / early-00s dad was doing some side work for instructors at the tech school he was going to. Making firends getting flying lessons, etc. One of them gave him the 30-30 to pass to me. The foreend furniture looks slightly different, it has a cap instead of a barrel band. but I intend to see if the regular 94 parts will actually fit someday. (About 95 positive they will.) Since it doesn;t carry the value of an actual 94, don;t mind using it and modifying it to how I want. Thinking about sending it off to be fullt refinished with a matte/satin black cerakote, then installing a Boyd's Pepper Laminate stock. Fancy it up a little bit while also giving it some better weather protection.
Never had my hands on a 336, so can't speak to them. I have got the other Ruger lever action. Brought dad's Ruger 96/44 to take to the range when I'm shooting the new SBH and the Taurus Tracker 44. It's a pretty dang good shooter. I'd rather have another model 94 in 44, but good luck finding that at a price/condition that I'm willing to purchase. I probably shouldn't be fussing about price though. I recently found out that Henry makes 2 Eagle Scout Tribute rifles. I already knew about the 22 and wanted to get one someday, but just found out that they also have a 44 version and now I want it too. When/if it happens, that is probably going to make a Model 94 44 look reasonable.
Event Coverage
TRS Merch
