modelageek
- Jan 31, 2009
- Boston, MA
- 4.0 V6
- Automatic
I have been having a clunking issue for a few years with my drivetrain....6 months ago I changed out the clutch , PP and slave.the clunk was still there. it seems to be getting worse. I have checked everything I can think off, u joints, suspension etc......I am starting to believe it is from inside the tranny.......it does not matter what gear it is in, even reverse. there is a clunk like a bad u-joint as you drive.....the truck shifts OK......I have looked at motormounts and tranny mount......is there one issue in the tranny that would give me this clunk no matter what gear it is in?.....I also got under the truck when it was in gear and sway it back and forth.....it seems to be traveling to far as iit goes back and forth.......I do have a slight bang on the front drivers side suspension when I go over a bump..the shock is new the upper control arm is new....I looked around for an issue but can't find one there either.......I don't think they are related but I thought I would mention it....TIA
