antifreeze leak?
ncsdaonex
i have anifreeze leaking all over the ground when i fill up my radiator. i think it is leaking from the intake manifold from the gasket. it leaks out untill there is it is about 1/4 full. it still seems to keep the motor cool with only 1/4 full. is it okay to drive like this. it isnt even close to overheating. the guage doesnt even get to the middle if i run it for 30 minutes.
it is a 1990 ranger 2wd 2.3 4 cylinder 5 speed
If you're in a cold climate it would be ok...but I would suggest changing that gasket ASAP...you could end up with engine damage if it does overheat...and that could happen on a warm day...
Your temp gauge may also be wonky...I'd check the connection on that again...
