Another v8 ranger...
Junglejoe
Columbia Missouri
I just pickwd this up last night. It's a 4 cly truck. Ive never messed with a 4 cly truck before. Is the 42 pin plug the same as the 3.0 as far as the 99-01 explorer/ mountaineer plug?
Not likely, but I bet it's VERY similar. Then again it would've made sense if it the dash harness for a given year fit all engines in the lineup.
I'd recommend getting an EVTM- electrical/vacuum troubleshooting manual- for your truck. It will show the wiring schematic for all the engines used that year. Also, being a 2006, make sure an engine swap is legal in your state before doing a lot of work and spending money.
I get the impression OP has done V8 swapped Rangers before.
It is definitely not identical - that would make it too easy! You will need to get the wiring books so you know exactly what everything is.
