nbaisden
I am currently having the same as another user had with his ranger. When i turn the truck on, you can hear the fuel pump kick on and once i turn the key, the solenoid clicks once, fuel pump turns off and all power on the truck is lost. Here is where it gets tricky....Once i reset the negative on the battery(pull off and put back on) it will do the same thing again. I have replaced the battery, the starter solenoid, and the starter. I got the starter tested and it was defiantly bad. But now that i have the new one on it still wont start. I tried the whole UN-plugging the alternator trick(i unplugged both connectors and the master connector) and then tried them one at a time with no result. Please help! you can call me tonight if you would like. I am working night shift from 5pm until 1am so i am awake. call me anytime. I would like to try to look at it more when i get home from work... Thanks!
Nick Baisden
440-339-9313
Nick Baisden
440-339-9313
