holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
under hard braking my truck will lock up the rear tires and the front brakes don't seem to grab too well. the hard brake lines were a hack job when I got the truck, I replaced all of the hard line using what I removed as a guide. I'm running the 9 inch rear brakes, they are properly adjusted and they don't hang up. the front calipers are new, as well as the pads, and soft lines. the calipers are meant for a 92 explorer (easier to fit extended brake lines on due to the different location of the banjo bolt) but they fit just fine on the D28. there are no leaks or air in the system. Does the master cylinder have an internal proportioning valve or is there supposed to be something additional on the frame somewhere? This is on my 86 with a 6 inch lift, 33 inch tires, and a flatbed (FWIW I had the same problem with 31 inch tires and no lift) If there isn't supposed to be anything else I would imagine that my weight distribution would do it. (heavy front bumper, 2 batteries, OBA etc...)
Is there some kind of addition that I can make to the system to proportion it a bit better without installing one of the aftermarket proportioning valves? (different master cyl, etc...)
