crazyjim
- Nov 13, 2013
- Automatic
So my 92 Ranger with a 4.0 OHV w/ a 5 speed has developed a curious new issue. The truck has been parked for several months and was recently brought out of hibernation.
The issue I'm having is what I believe to be a bad ECT sensor. The truck starts fine, idles a bit high, temp gauge rises into normal area. If I give the truck light throttle, it sputters and dies. If I goose the throttle to about 1/2 it revs quickly without a hiccup, but runs extremely rich, and bellows black smoke.
Driving produces the same result, if I get hard on the throttle, it accelerates normally, but if I try to maintain a speed at light throttle and accelerate slowly, it hiccups and bucks and jerks until I push past it.
From my small amount of understanding on this, if the ECT sensor is bad, it's telling the computer the engine is dead cold, and overfueling for normal operating temps. This would somewhat make sense in that any throttle input would deliver too much fuel for the air being consumed and stall the motor. However opening the throttle body quick enough allows enough air to continue to run.
If someone could let me know if this sounds like I'm way off base or not that'd be excellent. I realize an ECT sensor is a cheap part, I'm just not a fan of replacing parts willy nilly to find the solution. Thanks TRS!!!
