- Sep 4, 2007
- Age
- 38
anyone out there ever try it? it is sold under a bunch of different names. its as simple as soldering with a propane torch. thanks.
I forget exactly what it is, Aluminiod rod, something like that. Basically soldiering it. They use it to repair boat props and radiators, because of it's ability to build up from the initial base metal. Gas welding aluminum is more frustrating than your girl-friend going through "her time of the month". I'll only Tig aluminum. It's not like steel where the oxide coating has a lower melting temperature. Aluminum Oxide has a higher melting temperature, than the base metal aluminum, which must be removed before welding.
check it out meow
brazing is done with brass. This would be considered gas welding, much different because you're actually welding the metal together. Brazing is kinda like just putting glue on it..
NO, brazing is no done solely with brass. Brazing is a process whereby a non-ferrous filler metal ( no iron, "FE" on the periodic table ) or alloy is heated and bonds two or more close-fitting parts by capillary action.
Jay
